Hey,
I've had the Spec Stage 2 clutch now for a little over 1k miles. I did brake it in and all, and I don't even beat on it now. Initially after the install I noticed that the clutch would grab much higher than the stock clutch did. And after about 700mi on it, it would not grab much until the very end of the pedal travel. I then adjusted the clutch pedal to a lower grab position. It worked ok for a little, and now it's starting to grab at the end of the pedal travel again even though I adjusted it to a low position. It's OK, not great, but OK when it's cold, but after driving for a little bit it starts to become weaker. It holds ok while driving, only while taking off from a stop it doesn't want to grab at all. My brother tells me that it was actually slipping while he was driving once, but I'm not able to reproduce that yet. I took it for a hard drive and it held ok. I also have the CS SS clutch line, and I'm pretty sure I have no air in the lines. The clutch pedal is very smooth and much lighter than stock though.
Thanks.
Thanks.
