Okay everyone, I got my head unit, I got my door speakers, and recently just got my sub. Now I need the final piece to my audio system, the AMP! I've tried to browse as much as I could through older posts of this forum, and I've gained alot of knowledge. But I still some have questions...
Does gain control the amount of power output? (For example a 50W rms channel will put out 25W rms when the gain is set to half way?)
I know not to run RCA's and the power wire together. Is it okay to run everything else together? What about Speaker wire along power wire or RCA's?
For the P5, is it better to put the amp under the driver or passenger seat? (I'm guessing the driver's side is more convenient since the battery is on that side...)
What kind of crossover settings should I look for?
Is the bass boost option something I should opt for to add bass to my sub?
What size speaker wire should I use for the sub?
(I researched that the stock speaker wires should be able to handle 40-60 rms watts fine. So I will splice into the head unit's wiring harness for that.)
I've been looking at the Alpine line of 4/5 channel amps the most, since I've heard good things about them. However they are pretty expensive when bought brand new (except for the MRP-F240). I almost got the MRV-F340 used on Ebay, but lost the last 30 seconds of the auction battle. I was wondering what other brands/models I should look into. Also if there are discontinued but recent models I should look for such as the Alpine MRP-F320. The MRP-F320 or MRV-F340 would probably be perfect for my setup. I was thinking the MRP-F240 @ 40x4/100x2 might not be powerful enough (for my sub), unless Alpine usually understates their power ratings?? I really do want clean good quality sound and power.
Here are my speakers/sub:
Front: Alpine Type S 5x7's w/ 40w RMS
Back: Pioneer 6.5's w/ 40w RMS (I'm just using these as rear fill, so not really important to amp them, although I would like to if I can find a good deal on a 5 channel amp)
Sub: JL 10W0-4 with Sealed Enclosure w/ 125w RMS
ps.. i know i have asked alot of questions, hope you guys aren't annoyed yet! i really do appreciate the responses i've got so far...
