New wheels, what you think?
CitizenPro said:
im getting them from Mazdamp3_18.......he quoted me $100 a wheel for the 17's, but i want 18's and he hasnt gotten back with me with the price. Can you beat his price? if so im your guy.
DITTO. also trying to get prices on falken tires for both the 17's and 18's. what do you reccomend?
id go with 17 because the falken 17"s only have 40mm of offset. use a 2154017 tire or like i did so there will be no rubbing issues i used a 2054017
those rims are sweet.. and can you post some pics of your PIAA fogs when you're done with them? Just wanted to see how that would turn out.
ill most some pics with the fogs when i can figure out a way to install them. the 3in bolt idea was not wanting to work for me yesterday without aiming the lights towards the center of the car.
i would use a 2154017 if you used different tires. but the ones you have will fit but they may rub a little in the back if there is anything heavy in the trunk or backseat
looking good. what drop do you have? have you tried loading up the car yet? and are you running any negative camber, and if so, how much? thanks!
i have the eibach pro kit on it and the trunk is loaded in the pictures with over 200pds of stuff and no rubbing.
i have slight rub when packed with heavy weight in the rear........i have 17's with +40 offset and 205/40 tire, o yeah with a 2"+ drop also :D
