Just got my new 3 last week (Lava Orange HB) and LOVE IT! Spent lots of time researching cars and finally decided on the 3 and not regretting it. This site has been really nice in finding answers to some questions regarding upgrading. I just thought I'd share my experience.
One of the first things I did was get the kit and wire harness to replace the radio with my Alpine CDA-9815 MP3 player. The kit fits nice. The LCD replacement pocket fit isn't quite as nice but passable. Removal of the "carbon fiber" piece was easy thanks to instructions found here.
My next project was to install an aftermarket alarm system. Everything went pretty much painless thanks to a wiring diagram I found here except the door trigger polarity is positive, not negative. And, the front passenger door wire is located behind the glove box, while the other door wires are found in the passenger kick panel. Keyless integration couldn't be easier, but needed two relays (lock is ground through a 1K ohm resistor, unlock is straight ground).
Next, I ran some power wire for a sub amp. I looked around here and the place that was suggested to run the wire through the firewall was inaccessable due to either the clutch and the cruise control. So, I drilled a hole right above the fuse panel (removed the glove box) about 2" to the right of the two A/C tubes.
I plan on using an "old school" RF punch60ix DSM (the old style back when they were actually good stuff - this one comes in at 270w rms mono) on either an Alpine Type R 12" sub or an old RF punch power 10" sub (again, old school). The problem I have is with the speakers. I have a set of Diamond Audio Hex 6.5" components but I don't want to run another amp to power them. My deck is supposedly 30w rms x 4 channels, but hesitate to power those nice components with deck power. My other option is to get some lower-end speakers, but then I won't be using those expensive Diamonds. I am already downgrading from my last car which had two PPI PC2150's (2x150w rms); one running 600w rms mono to the Alpine sub, and one running stereo for the components. I really don't want to put those in my 3 - they were heavy and required lots of battery current. So, I have 4 GA power wire and RCA's run, but still haven't decided what I'm gonna do about the speakers. :'(
