New to the MS6. What are the top 4 mods to start with?
Searching helps... This has all been covered a million times. But, since we are here... LOL...
Motor Mounts
Intake
Shifter w/bushings
BPV
Why don't we have a vote of all the mods people actually have done and go off those numbers instead of speculating?
kind of performance because some people have had problems with the stock bypass valve leaking and bleeding off boost
so if my stock bpv holds boost almost to redline then it wont help me right?
sorry for the hijack last question i swear : )
see its kind of hard to tell at stock boost most times when the bpv bleeds off boost at the stock boost lvl's the turbo will just overwork itself to compensate for the boost loss. You dont really start noticing it alot till you get in higher boost ranges where the turbo can keep up the boost because its out of its efficency range
I would say the 4 top mods are:
1. intake
2. bpv/hybrid/bov (maybe not for performance, but people do it)
3. motor mount or inserts
4. test pipe (with or without downpipe)
I would also guess that gauges or dashhawk might be within the top 4
