Please Help, I have a shifting problem:
I got a protege5 about 3 months ago. I am a rough driver, but I don't think that I'm that bad.
I usually shift at 4500, including the first gear
, so I wanted to protect my car...
Therefore, I had a tranny flushed to have BGSynchrotech full synth. + additive, and my engine is running pennzoil platinum full synth.
Here is the problem, before tranny flush, didn't always shift smoothly into second. After the tranny flush, I still have a hard time shifting out of first into second, but now it almost feels like I touch teeth and then they fall into place, but they don't really grind.
Some tests:
Does not happen if I double clutch
Happens less if tranny is warm vs. cold
Doesn't always happen
So I think my possible problems are:
1) fluid too think for the temp (around 40 - 60)
2) master cylinder going bad
3) air in lines
I don't think it's the synchros because it's frequent, but still intermittent
I've talked to mechanics, but I bet that 3/4 of the people here know more about our car then any mechanic would.
P.S, it's the first generation MP5, without the clear side marker by the door, if it helps... Thank you so much for your help
Some tests:
3) air in lines
