Strut mounts and stabilizer bushings wont cure the creaking noise. If you paid for them get a refund, if you are going to pay for them, dont.
The noise comes from the actual bump stops that "should" glide over the strut's rod when compressing. The problem is that the bump stops are either made of a material that does not glide smoothly on the shaft or they are way to tight to glide on the shaft. The cure for this is a simple squirt of white lithium grease or dielectric grease on the top and bottom of the bump stop.
Jack up your CX-9 and lift the dust boot that covers the bump stop squirt some grease. Lift the bump stop and squirt grease on the bottom part as well. Glide the "now" smooth bump stop up and down to lubricate and distribute the grease on the strut rod/shaft. Repeat this process on the opposite side (left or right) and voila! no more annoying noise/sound.
Since this part is somewhat exposed to water/snow/other external elements this procedure may have to be re done when/if noise comes back. Hope this helps!
