AZSpeed said:Hey......why didnt you ever PM me back about the HIDs....Ive pmed you twicce now. I did all that word tracking down kits for you and I get the big stiff thanks.
GI- said:One more thing to mention...
...that bend you got going to your recirculating valve can't be good long term. Eventually that tube is gonna kink on one side or both (especially when it gets really hot under there, then you will have some serious issues.
InsidiousMSP said:They are radiator hose bends that come formed in that shape. Not hose that is being bent by it's position. Those hoses are ment for heat much worse than what that location feels.
Originally posted by InsidiousMSP
As for your other opinion, please do what you feel is right for your car. I'm not going to try to persuade you or further explain the purpose of the intercooler or guess air temperature differences in different locations. It's all up to you what you think is best.![]()
GI- said:ambient temps in different locations under the hood are extremely important for obvious reasons.
GI- said:You know what would work pretty sweet with this set-up is the DGM ram air hood. I believe the opening on their hood is right where you have your filter located.
InsidiousMSP said:That's exactly what i'm planning to get.![]()
goonsquad said:I have no experience tuning cars. All I can go by is my intuitive understanding of how air temperature affects it's density and the resulting advantages of having denser air. As mentioned above and countless times before, the temp under the hood of the MSP is ridiculously high. I would be willing to bet the temp just behind where the fog lights go (I don't know the name of that area) is much lower and hence would improve performance if the intake was located there.
This leads me to another question. All of the CAIs I've seen for the MSP so far go to this bay and have a cone filter that sucks air that happens to be flowing through. Correct me if I'm wrong, but isn't this concept one step short of the "Ram-air" technique used by several cars (i've seen them on corvettes). These setups I've seen actually force air through a filter and then into the intake. It seems this method would be much more efficient at forcing cold air into the engine. Does this make any sense? If so, why aren't vendors making true ram-air intakes that utilize that space? Thanks for bearing with my lack of knowledge.![]()
jred321 said:really, the only way to convince people is to dyno one setup, take it off, and dyno the other setup. it's 90* turn vs. warmer air, which one is worse can only be proven by the dyno. now a heat shield around the "short ram" filter, and some tubing going to the front of the car to suck colder air into the boxed area would probably be the best setup.
