New Computer
the most leet setup evar:
A WoW Christmas:
<table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td width="100%">
</td> <td nowrap="nowrap" valign="top">
</td> </tr> <tr> <td colspan="2">
</td></tr></tbody></table>
</td><td nowrap="nowrap" valign="top"> </td> </tr> <tr> <td colspan="2">
Updated the BIOS and the temp is reading higher but no load is still 25 Deg C.
Spent the day adjusting the computer for a new CPU and a much longer GPU.. 8800GTX OC2
Each Front Fan is Variable.
All HDD are reversed.
Southbrige Cooler Clocked to make room..
I love how clean it is and the third fan makes the front look..
Max Temperature after 10 Min with case fans on Lowest (Air Cooled Case) Never broke 39 Degrees
My Setting
8X
FSB 1536
Bus 384.1
Mem 5:6
Mem 921
Corev 1.325
CPU Core 3.072 Ghz
Memv 2.00
Lately, AMD has Kinna sucked at making new products...
I would suggest building a new system rather than try to upgrade an HP. They are Proprietary and do not take well to modifications without costing a lot.
What videocard is that? I have an 8800GTS OC2 and it doesn't get that cool at idle. I guess youre power supply fan blows right on it tho
If you look again at the graph, THAT'S 95% LOAD
Same Card 8800 GTS OC2
It's the case..
It's the case..
oh i know its at load. but thats the CPU. Can you pull the GPU load some how? i know when i'm playing WoW it gets up to 78C. 64C right now just on the internet. I even have my side case fan flipped so it blows under the videocard instead of the CPU. I need a flow thru case like yours
I'm also a little confused by your pictures and the placement of the powersupply and video cards. are all the same pictures of the same Mobo and case? NeverMind i see
That was a Benchmarking Program Called Futuremark. Believe me, the GPU is under full load as well..
Here is the Current Network at my house.
If you need to back up your computer, bring it here..
80gb
80gb
80gb
500Gb
500Gb
500Gb
1.74 Tb External
320GB
320GB
320GB
320GB
1.28 Tb Upstairs
320GB
320GB
320GB
320GB
250GB
1.53 Tb Downstairs
4550 GB In Total
4.5 TB huh?
You know for years I have looked at you as a true inspiration. A real DIY kind of guy. Everything you touched seemed to turn to original perfection. Clean, stylish, unique... you could do them all in every project.
Now with this latest information you have shared... you've shown your self to be nothing more than a ******* nut case.
My heart is broken.
