StreetUnit
Banned
- 2003.5 MSP
NEW 2.25" Seemless Aluminum SMIC Hardpiping Kit
NEW ********** Seamless Aluminum Hardpiping Kit in 2.25"
Seamless 2.25" Piping
A blow off valve can be used in tune with the stock bypass valve. If you are confused, call for clearifiction.
http://www.streetunitpics.com/albums/**********-com/MSPpiping2.jpg
NEW Street Unit Performance Seamless 2.25" Aluminum Hardpiping Kit for the 2003-03.5 MAZDASPEED Protege
Kits will be ready ship out very soon. Once the kits are ready to ship, the deposit and special intro pricing will expire.
The piping is of the highest quality aluminum and craftmanship. Each kit includes 4-layer black silicone couplers and stainless steel T-bolt clamps. The ********** MAZDASPEED Protege hardpiping kit can be used with the side mount intercooler setup. Our kit is stock replacement and a bolt on installation. The stock bypass valve can reattach without any modification. The kit will work with the Injen, AEM, Perrin, and OEM Intake Systems. This kit is a perfect replacement for the expensive OEM plastic intercooler piping which is prone to cracking. Cracks in the OEM intercooler piping causes hesitation and decreases drivability.
Benefits of the Street Unit Performance Seemless 2.25" Aluminum Hardpiping Kit:
- Improves Throttle Response and Drivability
- NO Expanding, Cracking, or Leaking During Boost
- Smooths Out Boost Pressure Throughout Power Band
- Aluminum Disapates Heat and Cools Quickly
- Beautiful Addition to Engine Bay and Attracts Car Show Points
- Bolt On, Factory Replacement Install
Tig Welded Blow Off Valve (BOV) Flange can be added to the cold pipe for a single or dual valve setup.
Piping Finish is available in polished aluminum and metallic black powdercoat. Custom color powder coating allow 5-7 days, please call to order.
*Deposit is non-refundable to a credit card but 100% refunded as store credit.
