<div class="bbWrapper"><b>update from tech</b><br />
<br />
<br />
Tech tested the car and confirmed the vibration. They initially suspected a bent wheel, but with so low miles, there just wasn't one. Then they checked for wheel out of balance. They found drivers front wheel out of balance by 5oz. They took tire off, and the wheel without tire was in perfect balance. They put tire back on, and after correctly seating it, it was out of balance by 1 oz which they say is ok. They say the vibration has been corrected.<br />
<br />
<br />
<br />
However, the tech test drove car and car still pulls a bit to the left. Not as aggressive as previously, but it does. They are unwilling to release car. Which is nice to see they are taking care of the problem. They called MAZDA technical, who informed them another 2012 had the same issue. They have some strict test parameters they want the tech to perform. I.e. drive the car at certain speed, for certain time, at highway and local roads, and report back to Mazda. That is what they are doing this morning. Then they will re-align the car. If the problem persists, they say it is MAZDA's call. On the other car that has this issue, Mazda blamed it on the "crown of the road," and let the customer take the product. Service writer/tech isn't sure what Mazda will say today.<br />
<br />
<br />
<br />
They said they will have an answer by lunch time.</div>
