Needing your opinion
Mazdaspeed6
2003 Mica Black Mazdaspeed Protege
Hey guys,
I need get a little insight on my car, Im trying to see what hp/tq I will possibly get with the set up I have, My goal is 250 since the limit on our tranny's is about 260-270.
I have a thermal 3" Cat back , and a GHL S pipe, cats have been removed, so basically 3" all the way back. I have the MAM block and GT28RS. Fuel rail and injectors are stock, I chose to leave this alone for right now because of the richness in the MSP. I have An AEM 02 wideband, Autometer boost, elec oil, and EGT gauge. HKS Type 0 turbo timer, Greddy PRofec B and I have a Unichip. I am waiting to see how the car runs at 9-10 pounds without the unichip installed to see if I want to keep it or just sell it. The turbo manifold is stock, and I have a custom made FMIC with RFL Bov bypassed with the stock BOV. oh yea AEM CAI
Any Ideas on the hp/tq I will get with my setup?
thanks
You should easily see your 250hp goal. I would definitely get some sort of EMS though, very bad not too and I would know!
You realllly should get some EMS. You have an incredibly nice setup and with EMS you will be golden for sure.
For 250 whp the stock injectors -should- do you but you would be running at their limits. WRX 440's will put you on the safe side as far as injectors go.
Once again, except for the EMS, you mods are top notch and will get you to your goal with ease.
edit: I see you have the Unichip, just not installed. My personal opinion, install it.
dump the unichip, install a better ems and install bigger injectors, you can run alot more power then for sure
That's an option too. Microtech ftw! (wiggle) It's really not too much more than Unichip, and you can tune it yourself on the fly.
Dump the unichip. The unichip is perfect for running like 8 or 9 psi then leaving it. With the mods get the microtech and then you can do anything you want up to 20 psi with the map sensor that comes with it.
Can I get the site where this microtech is
