I figure you guys can help me out better than the salesman at the local shop...
I have a Sony XS-L1065G (full specs here). This is a DVC sub, rated at ~150W per coil RMS. I haven't yet bought an amp, because I'm not sure what I need. Honestly, I'm kind of confused. I want to get the most power out of the sub that I safely can. I was looking at the XM-6001GXD amp... (full specs here)
My question is this: the amp is rated at 600W RMS at 2 ohms. Is it safe for me to wire up the amp to the sub in series (pulling a load of 2ohms), should I wire it in parallel, or should I just get a 150WRMSx2ch amp and wire up one channel per coil?
TIA for your help.
TIA for your help.
