Need Help!!
PMPJUICE25
MAZDA PROTEGE 5
Im Tryin To Remove The Rest Of My Roof Rack But Cant Find Out Where The Rest Of It Is Connected To Remove It. Can Anyone Help? Thanks
PMPJUICE25 said:
Im Tryin To Remove The Whole Rack Assembly. Stripes That The Fillers Go In. Everything!!!!!!
under the headliner inside the car there are nuts ... i think they are 10mm you remove them and take the rack off ...
It's not hard. Take off all the plastic pillars. take out the small press clips in the back near the rear hatch. Pop off the lense to the dome light and unscrew it. The map lights are just pressed in so you should be able to pry it loose and then unscrew the visors and it falls out. I would unscrew the dome light last since it will hold the rest of the headliner up till you are ready.
yup, to do all this, u need to remove the headliner. it has been done before, but it just takes a long time... i had a how-to, but the site is no longer working, sorry
Here are parts #s for the full-length black inserts that slide into the gutters.
Left: BJ3D-50-9LOE
Right: BJ3D-50-9HOE
They're around $75/ea at your friendly Mazda dealer. (thumb)
