Need Help: Temp gauge install on 2010 speed#
dimaxxxl
2008.5 Mazdaspeed 3
Wondering if anyone has installed a temp gauge in their 2010 speed. I am dying to put one in. I need recommendations on a gauge and where you run it for a reading. Has anyone found an good service ports on the motor? Any help would be great. Thank you
Water temp. I want to know where to put the sending unit. The 2010 does not have a temp gauge and it bothers me.
I'm still looking into it. You can use these sensor adaptors that go into a
hose. But you want to make sure that your installing it in a hose that
comes from the engine and not the radiator. There is two hoses coming from
the water pump. The smaller of the two looks like the one you might want.
But I am still making sure that’s the correct one. So don’t quote me on that.
If no One has an answer in a couple days, I should.
http://www.redlinemotive.com/store/megan-racing/megan-racing-temperature-sensor-adapter.asp
Or you can just put one of these in the upper radiator hose (#4). (i think this might be the best way)
I'm at work right now. I'll look more at it tomorrow.
no problem man. It will probably be the way I put mine in also. Don't
mean you have to buy from that company. Let us know when you
get it installed!
