Need help protege 1.6!!!!!!!!!!!!!!!
bolock13
Hi guys like the title said i need some help with my protege I need to find out where is located the EGR valve and the IAC valve Its a 2000 1.6 engine I been looking every where no luck theres almost no info. for this engine
Thanks a will apreciated all you help.(boom01)
On the 2.0L, the egr is located under the throttle body. Being that the engines are similar, I can only imagine that it would be in a similar location on your car, but I don't know. Good luck.
you would get better resulsts if you posted your problem in the regular protege section, you can ask add a mod and they can move it for you or you can just respost it.
