Need help on changing the 2 belts on passenger side of engine-2001 Mazda Protege 2.0
larryjs51
2001 Mazda Protege 2.0 liter LX
Need help on changing the 2 belts on passenger side of engine-2001 Mazda Protege 2.0 LX. Does anyone have step by stp instructions or know where I can get them?
Thanks!
mazda_tech_toronto
February, 6, 2011 AT 5:31 AM
Youll have to remove the p/s belt first. Lossen the upper mounting bold on the p/s pump. The adjuster is under the p/s pump losen the adjuster retainer bolt then lossen the adjuster bolt. That takes care of the p/s belt. Now loosen the 12mm adjuster retainer bolt, go under the vehicle and loosen the alt mounting bolt and then loosen the adjuster bolt. Reassemble in the reverse order.
