^tyrant^ said:i guess ill just get the dual pillar from jegs and then paint it
on a side note what do you guys think of this gauge?
RX-KEVIN said:nice gauge but you should really think about getting a gauge that doesn't read up to 30 psi cause in stock trim the gauge pin will only move a tiny bit (not cool) I went to a junkyard and found a 30 hg-15psi VDO black face gauge from an older porsche (free) when I spike 15 psi the pin is all the way to the end of that gauge seeing it move that far is alot cooler than it barely moving
jersey_emt said:The full a-piller pods from jegs don't replace the stock pillar. It slips over the stock pillar. The instructions say to screw it in, but I just used mounting tape in a couple of key spots, and it's worked fine.
Eventually I'll get around to painting it to match the other pillar.
