Hey guys, I recently changed the valve stem seals on my P5 and now need to reset my timing belt. There is a marker on the crankshaft pulley, as well as a guide that is marked with a 10 and a T. It looks like if I'm aligned with the 10, then I'd be at 10 degrees off from top dead center. I currently have my cams aligned (with the I and E facing each other) and the crankshaft lined up at TDC. My car is NOT starting this way. Do I need to line up the crankshaft with that 10 marking?
Any help would be appreciated. Thanks!
