Superspec - there shouldn't be any issue with that. That's what I did when I replaced mine for preventative maintenance. I was one tooth off at first, but that was fixed and the car ran like normal. It seem you may need a helper to hold one of the cams in place while you place the belt on. I remember struggling heavily with this doing it myself because I seem to remeber that both cams were not at rest to get it aligned properly, but my motor is a 2.0. 25k miles later, my timing belt fails, so I have to do it all over again.
J.D.
