Thanks again for everybody's help I still cannot get the car to start. I have added some photos of the Haynes Manual and my car photos.
I have been able to find TDC, however the directions call for the Crankshaft sproket mark to face upwards. If this is the case then the car would not be at perfect TDC according to the guide.
So with a friend cranking on the car, I can feel for compression at the number one cyllinder and I know when that one fires because it makes a loud poof noise, and pushes my hand off. After doing this I moved the crankshaft back just a slight bit so that it would be on the top, and the camshafts were already on there mark.
I made sure that when putting the belt on I had no slack on the side opposite the tensioner, however the belt is a tight fit anyway, and there really is not much slack on either side.
now with the belt on there I turned the crankshaft like the haynes manual tells me to do, 1 and 5/6 turns clockwise until the crankshaft sproket mark is facing the tension set mark on the engine block.
I then tightened the belt down to the approximate torque specifications.
I then turned the crankshaft 2 and 1/6 turns so that the crankshaft sprocket mark was facing the top again.
When doing this all my marks for the camshafts and the crankshafts were perfect. ( I took photos which are listed below)
I then put everything back together tried to start the car and there was nothing. it attempts to turn over but will not start.
What I question is this, When finding TDC the sprocket mark is not facing up it would be facing another direction this does not make sense?
Another thing is that the Harmonic Balancer has a white painted mark on it which you are supposed to match up to the T mark on the timing guide, but once again if this were tdc, then the book tells you to make sure the crankshaft sprocket is facing up. (there is no disctibutor on this car, so I cannot use the rotor to determine where everything lines up)
*** I am totally stumped on this. If I had the money i would have towed it to a mechanic by now, but I am poor with 2 kids. ***
