While driving home on the highway today, my check engine light came on. I immediately noticed the temperature gauge was pegged on hot, turned the heat on full blast, and pulled off the road. The coolant in the overflow tank was boiling, and a lot of steam came from that area (front drivers side) right as I pulled over.
I continued to run the heat while making some phone calls . . . draining the battery in the process. Ended up roll-starting on I-91 by myself, not fun.
By the time I addressed the dead battery situation, the temp gauge was back to normal, and the check engine light was no longer on. I was right by an exit and pulled off.
There was an Autozone just off the exit, and they connected their code-scan tool. The worker told me it was reading a faulty ECT sensor code and that "if the ECT sensor fails, the fan won't come on and you will overheat".
The engine was waaaay to hot to try and replace the sensor in the parking lot, so I bought a new sensor, and drove home along surface roads with the heat blasting. The temp gauge would start to creep up, and then I'd get a blast of heat and it would drop down to slightly above normal. I stopped at another autoparts store and bought some pre-mix coolant by my house.
The car is parked outside now, cooling for awhile so I can replace the ECT sensor (looks like an easy job) and refill the coolant. HOPEFULLY this addresses the issue.
Any thoughts or input as to why the CEL just "went away"? Could it have had to do with the battery going dead?
