mp3-79bronco
- 2001 protege mp3
well i've finally bought all the pieces i need for a complete turbo kit.
Exhaust Section:
Obx T3 manifold
Tial 38m Wastegate with 5.8 psi spring
Custom open dump tube
Master Power .50 trim
Custom 2.5 inch downpipe
2.5 inch Catless SLS midpipe
2.4 inch Corksport Axleback
Corrugated egr line ran off of the midpipe
Gauges/Other:
Glowshift Electronic Oil pressure Gauge
Glowshift Manual Boost/Vacuum Gauge
Autometer Narrowband AFR Gauge
Dual A pillar Pod
FF Steering Wheel Pod
-4an Braided feed line
-10an Braided Return line
Custom Tapped Oil Pan
Millenia PCV Valve
Intake/Cooling:
Altered Customs FMIC Kit
626 manifold, gasket matched and ported
nsn thermal spacer
Black piping w/ blue couplers
Custom SRI
HKS SSQV BOV
Electronics:
MSP ECU
Split Second AFC V.2
VTCS CEL fix
The guages are already installed, as is the tapped oil pan, feed line, midpipe, axleback, and CEL fix. The fmic comes in tuesday.
