JasonKilpa
For those of you who remember me I had the 2002 Mazda Protege that was pretty much for show and that was about it. Well I'm in the process of parting that out and getting rid of it. I have now gotten a 1995 Mitsubishi Eclipse GST that has already had a lot done to it.
I plan on changing up a few things on it including the paint and interior in the very near future. Here are some pics and below that is the mod list of it.
Engine:
JDM 4G63T Evo III Engine
Evo III 16G Turbo Ported w/ 34mm Flapper
NGK BPR6EIX Iridium Spark Plugs
RC Engineering 550cc Fuel Injectors
Hayame Polished Fuse Box Cover
Hayame Polished Oil Cap
Hayame Polished Radiator Bracket
Hayame Polished Reservoir Cover
Hayame Polished Radiator Cap
Dejon Tool Intake Pipe w/ K&N Filter
RS Akimoto Silver Silicone Vacuum Hoses
Taylor Black Wire Loom
GM 3.5 MAF Sensor
Road Race Engineering Upper I/C Pipe
Road Race Engineering Throttle Body Elbow
Optima Yellow Top Battery
Nitrous Express N-tercooler Sprayer System
Slowboy Racing Stainless Steel O2 Sensor Housing
Slowboy Racing Stainless Steel Tubular Exhaust Manifold
Slowboy Racing 2G Front Mount Intercooler
Slowboy Racing Coil On Plug Setup
Turbo XS Oil Catch Can
Gates Racing Belts & Hoses
Tial 50mm Blow Off Valve
Tial 38mm External Waste Gate
Megan Racing 3 Stainless Steel Down Pipe
Magna Flow High Flow Catalytic Converter
HKS Hi-Power 3 Exhaust
B&M Fuel Pressure Gauge
FTS Aluminum Fuel Pressure Regulator
Denso (Toyota Supra Twin Turbo) Fuel Pump
Drive Train:
Shifter Shortened 2
Symborski Shift Stabilizing Kit
Electronics:
Blitz Dual Turbo Timer DC
Ignited Push Button Starter
Pocketlogger v. 1.02h for OBDII
MAF Translator
APEX-I AVC-R Electronic Boost Controller
Kenwood KFC-6909 6x9s (Rear)
Kenwood KFC-1687 6 1/2s (Front)
Kenwood KAC-9102D Mono Power Amplifier
Kenwood KAC-8402 4/3/2ch Power Amplifier
Kenwood CCD-900 Color Front View Camera
Kenwood CCD-900 Color Rear View Camera
Rockford Fosgate T1 15 Subwoofer
Mounted In Sealed Enclosure
2.0 Farad legacy Stiffening Capacitor w/
Digital Voltage Monitor
Exterior:
Custom Two Tone Paint Job
VIS O.E.M. Style Carbon Fiber Hood
VIS TSC-3 Carbon Fiber Front Bumper
Erebuni Z3 Style Carbon Fiber Fenders
GT Fabrications Carbon Fiber Hatch
Concepts 2 Reality Carbon Fiber Trim Piece
Custom Carbon Fiber Fuel Door
Polished Hood Pins
M3 Style Electric Mirrors
Kombat Side Skirts Fully Molded
97 -99 O.E.M. Rear Bumper Fully Molded
97 - 99 Style Chrome Projector Headlights
Pilot Motorsports PL-2038W Driving Lights
Suspension:
DC Sports Carbon Steel Front Strut Bar
DC Sports Carbon Steel Rear Strut Bar
Polished Lower Rear Tie Bar
Skunk 2 Coil-over Kit
Ingalls +1 to +3 Degree Rear Camber Kit
Specialty Products +1.5 to +3.0 Degree
Front Sliding Ball Joint Camber Kit
Interior:
Import Intelligence Aluminum Gauge Faces
Import Intelligence Aluminum HVAC Controls
Corbeau 3 Point Retractable Double Release Harnesses
S&W Race Cars 6 Point Roll Cage
Genuine Carbon Fiber Glove Box
Genuine Carbon Fiber Arm Rest
BBK Aluminum Racing Pedals
Aluminum Gauge Bezel
Lo-Tek Full Pillar Triple Gauge Pod
Autometer 2 1/16 A/F Ratio Gauge
Autometer 2 1/16 Boost/Vacuum Gauge
Autometer 2 1/16 EGT Gauge
Autometer 2 1/16 Volt Gauge
Autometer 2 1/16 Oil Pressure Gauge
Autometer 2 1/16 Water Temp Gauge
Pro-Form Shift Light
Wheels & Tires:
18 x 8 Axis Decade Front
18 x 8 Axis Decade w/Maxis Lip Rear
225/40ZR18 Nitto Neo Gen Tires
Miscellaneous:
Mitsubishi 3000GT Dual Piston Front Brake Calipers
Shaved Reverse Lights
Molded Rear Bumper
4th Gen. Toyota Celica Third Brake Light
Removed Cruise Control & Air Conditioning
<!-- / message --><!-- sig -->
Engine:
GM 3.5 MAF Sensor
Drive Train:
Shifter Shortened 2
Electronics:
MAF Translator
Exterior:
Polished Hood Pins
Suspension:
Interior:
Wheels & Tires:
Miscellaneous:
Molded Rear Bumper
