I got in touch with the owner through email, back and forth and arranged to pick up a couple parts while I was in the area for work.
He is pretty good about getting back to you on his email.
They are on FB as well. Gabriel Tyler is his name.
An SR swap in a 510 isnt that bad, it requires flipping the front cross member, custom mounts (which are pretty easy to come by these days) a modded trans x-member, and a shortened drive shaft. Some trans tunnel cutting is also in there...
the wiring isnt bad at all, I believe 4 or 5 wires get spliced into the 510 harness if it is done that route.
I think the hardest part for me will be intercooler mounting and plumbing....
