Hey Danny, if you're wanting to go with ITBs, check out the gsx-r throttle bodies on ebay. They go for $20+. I'm sure with a little bit of fab work, you could get them to work. All the linkage is there, as well as a place to mount the TPS. I was debating this, but didn't want to deal with the MAF. Although, if microtech allows you to tune with the TPS, it might not be that bad to get it to work. They already have vac lines coming off of them, so you could hook up a vac block to run the brake booster, etc...
