i recharged my air filter.
i tried cleaning my egr valve, but i couldnt get those damn bolts off. i wasted my whole entire day.
ll change the plugs maybe this weekend. what are you all using?
NGK ZFR5F-11 long reach plugs in mine. NGK.com, 2.52 each. Use 2000 protege with 1.6l on their site.ll change the plugs maybe this weekend. what are you all using?
I heard from somewhere that this "shuddering" is due to the EGR valve going bad. My P5 has been doing this more and more lately, mainly when I'm sitting at a light. It started around 90K miles and has gradually gotten worse. I'm at 119K now.
I'm hesitant to spend the $$ until I know for sure what the problem is... Tune up w/ plugs doesn't make it go away.
i cleaned my egr, what should i use as lubricant? i used liquid wrench...
basically i was driving home from work last night, and i started the car up, and as i started driving off, and i got to the stop light my idle goes crazy, up and down several times, then just dies.
i cleaned both my IAC and my egr idk whats going on.
Sounds like your MAF might be bad...if you already changed your plugs correctly, I would say get some maf cleaner and see what happens...It's a crap shoot at this point...Maybe seafoam it also (the engine, not the maf!)
