I too thought my sendor was toast- until I grounded it. Now it works great. If your sendor is installed in the middle of a rubber tube, it HAS to be grounded.
yea, mine works fine. its back to normal. i'm using the stock sensor that came with the temp gauge. i have a single wire coming from the gauge to be used as the ground only for this gauge so i know if it works or not. i have the ground at the loop behind the engine right above the IM. i believe it is a engine hoist spot? not sure though.
