My first leak at 7K miles..
prboy3
Mazda3 Black Mica Auto
hi forum,
just moved my MZ3 and found about 7 drops (probably more or I say a lot) of brake fluid (I think) over at the right side of the car, in my driveway. Yesterday, I ran over a big nasty hole in the freeway. Precisely the right front tire got the hit. Went and looked from where the leak was "comming" I saw one of the brake lines of the right front tire wet with fluid. But the thing is, the brake fluid is all over the right side corner of the plastic plate. I Check the brake fluid level and it was fine. I have to go to the dealer.. is that leak covered by the warranty if I have taken out the air resonator? please tel me YES...
Help a brother out...
Thanks,
PRBOY3
If you damaged it I doubt it will be covered under warranty, since the warranty is for factory defects.
Considering the air resonator is on the left side, I would think you'd be ok. If the damage was caused by a pot-hole, your insurance should cover it.
