interior restoration
pulled the door panels off. The plastic sheet water seal thing definitely needs to be cleaned and resealed. I took it off to see if i could fix the lock actuators on both sides of the car since they dont lock, but im thinking Ill just have whoever installs my alarm fix it.
As you can see the panel is ****** filthy. 22 years of dirt and grime. You can also see the void of grime where the door handle was. Im going to shampoo and extract the panels on sunday.
rear hatch struts are busted, so i propped it up with a broom stick. And yes, it fell once while i was underneath it. And yes. It hurt.
Interior pieces coming out to be cleaned and reinstalled.
what the trunk looks like stripped down. The wires you see are for the fuel pump switch.
some broken glass i found under the carpeting. Car was definitely broken into in its lifetime. Also would explain why the passenger lock doesnt work at all.
Removed the seat, This is before what the carpeting looked like.
after. Looks better, but needs shampooing. The carpet definitely needs to be pulled for a proper cleaning, but the previous owner, or whoever put the T2 seats in welded on of the corners to the floor. Im guessing because the bolt would thread. (the 4 bolts i pulled on the pass side were all stripped) So ill have to break the weld to pull the seat, which im unsure if i want to do yet. I want to replace the insulation under the carpets with new insulation so they s*** doesnt smell like the 80s anymore. and i cant pull the carpet without pulling the seat.
dirty crossmember
pulled off the doorsill and cleaned it and underneath it.
cleaner
how it looks as of now
cluster **** of parts that will be cleaned on sunday.
3/1
before. Managed to pull the drivers seat out. where one of the bracket had a girly weld which a manhandled with my bare paws.
after. Seats not installed as they still need to be cleaned.
The door panels were pulled off and cleaned with APC and a extractor. Managed to get them pretty clean. Floors were brushed and vaccuumed.
Trunk all cleaned up. Pulled all the carpeting and panels. Wiped down the floorboards with APC and a cloth.
cliche dog sitting in car seat picture.
