Hey, I'm looking to pick your brain about going with the stock dampers with the Corksport springs. I might go this route pretty soon. Hows it been riding? Driven over any large road imperfections? Like anything large enough to feel in the cabin? Hows the handling on spirited drives? Thanks for any info.
Thanks for the info. My only concern is the back of the car looks like it might be a tad too low for my liking. It could also be the shadows from the sunken in stockies as well. I'm kind of agonizing over this decision. At first I was going to go with the RB springs because I knew I'd be on the stock dampers for at least another year. But the more I looked at them the more I disliked the mildness of the drop. The H&Rs look great and I think the drop is just about perfect but the spring rate is too much for a fatory damper, I believe. In terms of rates, the CS springs seem to be the happy medium between the RB and H&R. Although they do seem lower than the H&Rs. Sigh...
You might be right. Too bad I installed Corksport springs on Thursday. So far the ride is... decent I guess. I'm pretty unhappy with the the way my car handles bumps right now, but I knew that pairing the springs with standard dampers wasn't ideal to begin with.
Install went smooth except for not being able to get a good torque on the top 17mm nut up front. I had my alignment shop handle that for me. I saved the rears for last as a "cool down". I cleaned up and painted my rusty hub centers black while I did the rear springs.
The rear springs rattle a bit over bumps. I'm guessing the coils touch each other? Anyone else have this happen?
