MSP vs. P5 front rotor size?
I had the guys at Midas try to compress the piston (while I was standing right there) with a big set of pliers and it didn't budge.
This is the second front caliper (not sure if its the same side) and also had a rear one replaced not too long ago.
I have CS SS brake lines all around and non-ABS.
Not sure about the fluid, valve or master cyl. but I will get the system flushed out.
How would I test the proportioning valve or master cyl?
I do live where there is a lot of salt and sand, maybe thats a factor?
I will get some good pics once I get the replacement installed.
I am seriously considering moving up to the Wilwood DynaPros.
Tekkie sent me a CAD drawing file of an adapter bracket.
I spoke with FASTBRAKES who Wilwood recommended. I would have to get a nice sized group together to make it happen, but it would be a nice upgrade and cost half the BBK (maybe $800-900).
Some pics for comparison:
626 on left, stock P5 on right
Yes. They fit fine, as the 626 came with factory 15's on most of them. You could even go to the even large 03-05 Mazda6 front brakes, and even those fit 15's.
