MSP stock turbo fit Protege MP3
carrt1mp3
2001 Mazda Protege MP3
Hey, I was looking to boost my MP3 and was wondering if the stock turbo on a MSP fit directly onto a MP3? If not how hard (if possible) are the modifications? Thanks!
Just line up the bolt pattern from the MSP turbo onto your MP3 and see if the holes line up. It should be compatible other then that make one phone call to The Mazda Dealership and they will tell you right away!
you can purchase a full msp turbo kit set up. they usually pop up in the for sale section. t25 turbo, manifold, purchase SS oil feed line, return line, and youll have to tap your oil pan unless u plan on purchasing a msp main bearing support plate which is tapped for the oil return from the factory(you have to unbolt the trans in order to do this) MSP ecu. water lines. etc. u shouldnt spend more than $800-$1000 doing this
Just saw this! Thanks so much!
