MSP Fog Light Problems
HFD45
Contributor
MSP No. 970
In this past July i noticed my Driver Fog Light was not working, so i figured what the hell i'll just replace the bulb that has to be it. Well it was fixed for about until now when that same fog light went out. I tried looking for stripped wire coating or anything that would be damaged. No damage what so ever, im stuck guys!!! I need some help ways to narrow the problem or even find the short if there is one. Thanks in advice.
could it be the fuse?....they each have their own fuse, try changing it
This might be an obvious but make sure you dont touch the bulb when you are changing it. Also when you put in the new bulb move the wires around some and see if you can get it to go out again.
