well not so fast there - i know bryan has a thread going where he has compression problems. number one, depending on the turbo size, 6psi is more than enough for most stock protege engines. number two, the mp3 ecu is totally unsuitable for boost being that it has advanced timing. number three, if he's not using any other method of controlling timing and/or adding fuel its easy to see why his engine is losing compression.
