MS6 ECU pinout
Bigg Tim
MazdaSpeed 6
Does anyone have an ECU pinout? It's got to be out there if there are some tuner companies that are developing engine managment for it.
If you can make sense of these 2 attachments. Please share if you do.
I think this is the best we've got at the moment.
  • PCM Wiring L3_TC.pdf
No I need something that shows what each pin is. Like pin 88 is the TPS, pin 87 is the MAF, pin 26 is the coli driver 1, pin 52 and so on. That's like what I had for the protege, a listing of what each pin is.
Where did you get the PDF? Is it from a manual? If so, I would think the ECU pinout would be in there.
On the connector, there are numbers for each pin that would go past 100, so the numbering on this PDF is not what is on the PDF. Thanks for the help though.
edit-- as I was, that is how the pinout is on these.
As you know I have access to it. Anything specific you need?
Ahh the man has arrived. Yes, I would like the whole thing if I can get it. I may hook up an MPI, so I guess the coils, MAF, TPS, O2's, Crank position sensor, Cam position sensor, injectors......everything would be awesome though. If you didn't want it posted, I would keep it between Nick and myself.:) I can PM you my email addy.
Its from the technical highlights manual. That is the closest thing in there :-(
I thought I'd contribute what little I have. Those characters in the little bubbles mean nothing to me.
I am waiting for a pinout as well so I can implement my tuning solution.
Well give me about a week and I'll have the ones I use for the afc mapped out...tps, o2, maf, etc...won't be all of them but it'll be enough to get ya started...
New Threads
