I generally use the automatic climate control in my MS6. I've noticed that the climate control system always turns the AC on. Right now, it is 4 degrees F outside. I have my climate control set to 66 degrees F and the AC is always on. To me, this make sense when the defrost is on. But, according to the display, sometimes the defrost isn't on. But, the AC is still on. If I try and turn the AC off, the climate control goes into manually mode.
Is this normal?
Is this normal?
