MS3 Track advice: Brakes and tire pressures
joe149
2008 Mazdaspeed3
All -
Am headed up to Lime Rock Park next week to run a NASA HPDE event in my 2008 MS3.
Questions:
1) Have just put new Toyo R1R's (225/40) on it. What hot pressures should I aim at? I saw an article in Grassroots comparing R1R's with RE01's and they were using really low pressures - like 28 lbs (this was on a Miata). My experience with my old BMW with Bridgestone PP S-03's was they wanted 40 or so hot. Any comments??
2) Are the stock brake pads adequate for 2 days of track?
tia,
Joe
I just went to the track yesterday and I set the tire pressure cold at 36 for the front and 34 for the rear and they got to 40 hot. One time they were above 40. I put my hand on the tires after I ran and they were hot all the way across, and that is what you want. I have RE-01's tires for the track.
The stock brake pads are fine for now. I did upgrade to hawk plus pads after a couple of track days. I switch between the stocks and the hawk's and because they are made of similar material and I don't have to turn the rotors. The get bedded fine.
07 Silver MS3, Mazdaspeed CAI, Mazdaspeed CBE, Mazdaspeed coilovers, TWM short shifter and bushings, SU rear engine mount, Hotchkins RS, Cobb shifter weight, Cobb turbo intake, Goodridge stainless steel brake lines, Motul RBF600 brake fluid, Hawk plus pads (track only), RE-01's (track only), Dashhawk, Fuel-Filler door.
I agree, my stock pads held up fine, but I'm also upgrading to HP+.
Stock pads are pretty darn good at the track. Maybe upgrade fluid to Super Blue or Motul.
