MS3 Sport ready for audio upgrade
The RE-Q will work for what your trying to do. Myself, since I have the Bose HU, I'm just running an LOC. But, if I had to chose between the MTX RE-q & the Cleensweep. RE-Q for sure. Cleansweep is too pricey for what you want to aclomplish in my opinion.
Wanted to clarify some things
Lets clear some things up here for everyone:
Sensitivity – The sound pressure level produced by a loudspeaker, usually specified in dB, and measured at 1 meter with an input of 1 watt or 2.83 volts, typically at one or more specified frequencies.
Maximum SPL – The highest output the loudspeaker can manage, short of damage or not exceeding a particular distortion level.
It is possible to have a "lower power" (power rating) speaker play louder with less power than a "high power" speaker, and visa versa. It depends on sensitivity. Compare a horn tweeter with 5 watts, to a 18"subwoofer with 10 watts. I guarantee the horn will be louder. But the opposite can happen also, it all depends on the speakers. You can't really make a blanket statement either way just on power rating.
Even sensitivity is not a linear measurement. If you want to know which set of speakers will be louder, buy both and compare them.
The MTX RE-Q will attempt to recreate lower frequencies to add a subwoofer to a system. (Frequencies filtered by the factory headunit).
"Bass restoration signal processor Get full bass response when adding amps to a factory system". Really does not "clean anything".
The JL Cleansweep, will remove all of the factory equalization of the head unit, making the signal a "flat response". The draw back to me, is that you also have to use the volume on the JL unit so it receives a consistent signal for it to adjust. If you changed the volume on the headunit, it might change the factory equlization.
Th JL unit basically makes the factory headunit a "high end" headunit.
Before buying either, go to the mfr webpages, and read the specs, then decide what you want.
And finally every 3db increase in SPL is twice as loud. Not 10 not 2, but 3db.
I have the GT with the Bose, and I just went total homebrew on the line. I have a digital pioneer monoblock at 300W RMS driving a 4ohm 12" Boston Acoustics G5 at 450W RMS max. I tapped the bose amp under the seat, ripped up a radio shack RCA, separated the positive and negative for L and R channels, and fed those preamp levels to the pioneer amp. As Emeril says, "BAM!"
The thing hits hard in a 1 cu. ft. enclosure, overflowing power, but most importantly, very VERY tight. Much tighter than my old JL 12" driven with a kicker 300W amp. My cutoff is at 160, and talk radio is clean clean clean. But I also get great levels; really low notes around 20 - 30 hz still hit hard off test scales.
I understand you don't have the same HU application, just saying for those without money leftover after good gear for a dedicated LOC or levels cleaner, perfectly serviceable and accurate bass can be had with a little solder and steady hands.
Course y'all probably knew that...
In one or two years, my MS3 is getting a car pc... shh.. don't tell her...
I'm man enough to admit when I'm wrong, my apologies to ecniemann.
I was not aware that there was a difference measured in SPL(3db) vs. Audible(~10db), guilty of not thoroughly reading my own reference material.
