MS3 guys - want a gauge pod??
Thanks for the pictures!!! bummer, I thought there was a storage space up there. Well, maybe I can match the contour and just have something sit on top of the dash. Or maybe I could make a pod for the left-side of the dash between the pillar and console.
that plastic piece with the vents in the center of the dash lifts out separate from the rest of the dash. It obviously wouldnt be an easy peice to make, but it certainly would be possible
I'm on board to buy from you too! I want a solution...I would like to put a AFR and Boost gauge in the car ASAP....lol...just need something to mount the damn things in...52mm
theres a gauge pod that screws onto the dash piece..its 30 dollars but u have to cut the center dash to fit the gauges depth and the wires and s***
