MS3 Front End rattling Noise HElP
racersir
Mazdaspeed 3
Hey guys I have a 2007 MS3 and I'm getting a weird rattling noise in the front end suspension sounds more to drivers side but here's the weird thing when the car is cold or the weather is cold outside it doesn't rattle it only rattle as the car heats up or if the weather is hot outside which I live in PR which is basically hot all the time lol. At first I thought it was the sway bar bushings but does usually make noise when cold and I did replaced them about a year ago replaced struts about 6 months ago. Any ideas??? Could it be the end links??
Aftermarket swaybar links..?..mine with the helm joint fittings wore out and rattled. Have you checked the tightness of the strut top nuts and the 3 top mounting bolts ?
Latest posts
