Went back to Yimi Sport Tuning in Santa Clarita today. I've dynoed my Speed3 there before. I wanted to see the results after putting on the Cobb SF short-ram air intake. No other mods since my last dyno runs.
I was hoping to see about 10-15 whp gain plus a bit more torque. Technically speaking, I did gain about 10 horsepower. But I lost nearly 10 wheel torque in the process.
The most telling results are examining the AFR's from before & after putting on the Cobb SF intake. Clearly, the ECU needs tuning to support the full potential gains from the intake. It leans out (or holds higher AFR's) between 3K to 4K rpm. The AFR trend with the stock airbox is much more desirable.
Now this doesn't mean the Cobb SF intake is a bad mod. It just highlights the need to have a tool like the Cobb AccessPort and ProTuning (custom dyno tuned) ECU management in order to take advantage of the greater air flow. The ECU does not seem to do enough adapting to flow more fuel as the air flow rises. This risks detonation under conditions of poor quality gas. And of course, in California, 91 octane is as sweet as it comes from the pump. Except at the tracks where you can get 100 octane fuel.
So here's the dyno plot comparing the before & after installing the Cobb SF Intake:
The +10 hp gain is found only at the higher rpm's and that makes sense because it takes more air flow to make power at high rpms.
At least my ETS 3.25" thk TMIC proved damned consistent on the dyno. It helped having the fan box secured directly against the TMIC to force flow without the hood duct work. Look how repetitive all 3 dyno runs were.
Here are a couple pics plus a short camera vid of the first pull.
