bazooka joe said:haven't got back to the car yet, tonight...i'll triple check my wiring and look for any vac leaks. i should probably remove the second o2 which is doing anything (seeing it's before the cat!) but blinking at me.
Bigg Tim said:Why is your 2nd O2 before the cat??? Do not remove it, you need to have your car working properly before you start tuning. Put it behind the cat of try the MIL eliminator in the how to section. You need to get rid of all the codes on your car and have it running right before you try anymore tuning. That may be why your idle isn't smooth. The MPI doesn't mess with that. Fix the O2, this is a big issue since the MPI is a piggyback and relies on your stock ECU. If the ECU is pissed off, then the MPI will not be "allowed" to work properly. Car must be 100% before tuning.
bazooka joe said:i was figuring you'd say that! it's in the second bung on the down pipe. ya i need to get a bung welded in the pipe after the cat and block off the one in the down pipe. good catch tim!
supa saiyan pr5 said:Mark I have a O2 sensor just the sensor no wiring or anything that you can use to block the hole and then when you get a wideband then you can just unscrew the O2 and plug the wideband in.....let me know... and also
Thanks BIGG TIM!!!!....I really learned alot about the MPI that I didnt know when you helped Bazooka Joe and I out Friday night...
Jeremy
Bigg Tim said:No problem!(thumb) You'll learn more once you can tune more after the issues have been resolved. Take it easy on the auto though.
supa saiyan pr5 said:I'm on vacation this week so we might go at it again...
Jeremy
bazooka joe said:cool! i'm off all day thursday and was hoping to do the mil eliminator
for the second o2 and eliminate the cel and go from there. i rechecked
all my ecu/mpi and TM wiring last night...all the connections are
soldered and correct. i've checked for any vac leaks and none seem
apparent?? we've got to determine what's causing the fuel calibration
issue??
how's thursday for you jeremy?
bazooka joe said:first, thanks to jeremy once again for running the laptop while i drove...anyway tried to do some tuning but realized i had a gas leak from the 1st injector. i installed the MAM fuel rail and when putting the injector back in the rail i must have nicked the o ring....LEAK! the quest continues!! i should have the o rings tuesday....stay tuned!
Bigg Tim said:At least you found it.....Have you found anything else yet?
bazooka joe said:i just got the o rings so i'm going to get then in tonight. hay tim, what should the fuel pressure be set at? i had 40 psi? thanks!
bazooka joe said:yes, and because it's adjustable i wanted to make sure i had it set correctly...mark
Bigg Tim said:It's not a RRFPR is it? Tuning will be different with that, unless you get it set to stock pressure. Why do you have that, if I may ask? I'll get you your numbers when I leave work, I'll post them up tonight.
