- Banned For Being A Troll
Mazda Protege Five Turbo
Spring 2012...
-Front to Rear Carbon Diffuser to generate much needed aerodynamic stability (Flat Bottom with cavity in the middle and rear)
- GT3071 .63 and Re-Tune
- 4th Gear (0.725) Taller 3000 RPM = 123 Km per Hour
- 5th Gear (0.625) Taller 3000 RPM - 145 Km per Hour
Hello, I am Brian. I have been working on my Mazda Protege5 since I bought it in 2002.
There are not parts that were not specifically made custom for the car. Hardly any "Bolt-Ons", and even if they were bolted on, they were either prototype parts or the only one made.
I have just installed a Haltech Sport 1000 with IQ3 racepak display. I am the first person to install this engine management system on this engine running Direct Fire Ignition and Full Timed Sequential Injection.
It can be viewed at http://www.cardomain.com/ride/503974 in better detail.
(1.2+ Million Hits)
"I really think that Less is More if there is an extreme amount of "Less".
Each and every part is selected based on, Function and Reliability, Then It Must never stand out, seem out of place, and it must be part of the rest.
I do not want a bunch of parts in a car, I want a Single Perfect Machine."
Texas Mile Top Speed Mazda Protege, Gear Ratios for 300Km per hour at 7000 RPM
A Full out assault on Top Speed and Acceleration. A Grown-Up Kids Go-KART for the street.
- Fully Forged Engine
- Transmission with PAR Straight Cut Gears Set Specified Ratios (2.500, 1.550, 1.100, 0.770, 0.650 Final 4.105)
- Haltech Standalone ECU on Custom Trigger (36-1+1) Sequential Injection
- Direct Fire AEM CDI Coil On Plug conversion Multi Strike
- Quaife ATB LSD
- SPEC Stage 3++ R Pressure Plate and Clutch Disk (425 Ft/Lb Clamp)
- SPEC 6.8 Lb Aluminum Flywheel.
- K-Sport 14" 8 Piston Brake System
- K-Sport Hydraulic Hand brake
- K-Sport RR Aluminum Coil Over suspension
- IQ3 Digital Display Solution
- WORK Emotion Kai 7076 Forged Aluminum Rims, 18" Only 16Lbs
- Full OEM JDM Mazda SPORT 20 Conversion (Front, Rear, Lights, Badges)
- Full Weight Reduction
- Quaife ATB LSD
Spring 2012...
(1.2+ Million Hits)
