apowell0224
- '02 Protege5
Ordered a remanufactured 5 speed transmission from Man Trans Llc in Talahassee Florida. In the meantime i took mine out, When the freight truck arrived, the transmission i got had slight varriation to my own. But it has the same spline count and bolt pattern. So will it work? i need a hand identifying which car it came from if anyone knows
My Transmission Bell Housing:
The tranny i got. Theres two half circle cutouts at the bottom, but wont that let water inside? The inside of the bell housing is different as well.
Wanted to remove my rear cap and replace it with the other one because its a little bent. Couldnt do that because the gears inside are different. Looking inside my rear cap
And inside the rear cap of the reman tranny i got
So Will i be safe installing this tranny? or did it come from a different car? i Dont have ABS, so maybe this one came from a car that did? or from a different manufacturer altogether?
