Blitzkrieg
- 2001 Blue MP3 Protege #394, 2003.5 Yellow Mica MSP #1201
i just replaced my old motor mounts with the awr 95d race mounts. in the process i had to remove my throttle body and my intake. After putting eveything back together and starting the car it will not maintain an idle. it dropps as low a 100 rmps and spikes up to about 3500 rpms and then will stall. i took everything back apart to make shure i had everything connected correctly and i dont see any bad hoses or faulty connections. i also cleaned my egr just incase, none of this seemed to fix the issue. i have never had a problem with the car prior to doing this, ide was stable at around 750 rpms and never sputtered, does anyone have an idea as to what could have caused this or what is causing it??
