mp3 specs
ForBidden
mazda, mp3
what is the mp3 suppost to run in a 1/4 mile ive herd 16.4 16.2 15.8 15.4
what is the closted stock? i just beat a prelude on the highway yesterday a newer 1 like a 1999 thoes run like 15.7's i dono some 1 wanna help me out?
Bring your car out to the drag strip tonight (9/13) and find out. $10 to run. Gates open at 6. Cars on track from 7 to 10.
I don't know if tonight is actually on the schedule although it will be open:
www.teamwir.com
Low 16's, maybe a 15.8-15.9 if your a professional driver. The other driver might not know how to drive.
i cant go to the drags wont get back the car till monday the tranny was toast and there putting a new 1 in....
somone local claim his turbo MP3 ran 13.6 with 4.4 0-100KM
Is it even possible even with the boost.
how can the mp3 run high 15's when the other protege run at the high 16's? is the ecu that big a difference?
The timing curve is more aggresive so yes that just 10hp more (the mp3 has a better exhaust too) but I'm sure the curve will pick up power at a wider rpm range or more effectively. TQ should also increase. If you have a car is a DIZZY play with a timing light some time (note: use high octane for that) and you feel a good difference with a few degress of timing change.
Absolutley!! If they can drive it and the car is setup right, mid 13's shouldn't be a problem. I had a turbo'd MP3 so I know how fast they can be.
now is that with the motor built or the turbo just slaped on? im planing on buying a turbo kit. im gonan sell the mp3 ecu when i get my msp 1.
ill buy it off you so you can afford the new one?
if you know of another mp3 owner in your area...and a good mazda tech, he can flash the mp3's ecu to your car...i did it for a GA member. the tech only charged us $40 to do it.
what does flashing the mp3 ecu do? does it help recognize the bolt on mods or something?
no, if someone wants an mp3 ecu in their car (p5, protege), they can have a tech download the mp3 ecu from a car and flash it to the p5 or protege...so no one has to buy an ecu for $150ish...it'll save them 100 easy.
pm sent
Stock drivetrain with only an upgraded clutch.
are u serisous!!!! i may do that but i might still buy the msp 1 thoe i dono i got to figure out what kit im going to buy. im still waiting on joker to get back to me on his turbo kit! oh dibs on your shifter can u wait till wendsday!?
i could sell it to you. no i make about 3grand a mounth.
wow i just wet my pants!
