MP3 hazards lights
Bambammcd
2002 Mazda protege mp3
Hey I'm have a problem with my hazards coming on under heavy breaking. They also don't come on fully but flicker and make a buzzing noise like the relay is being activated to fast
Ok i found a wiring diagram but im having trouble pin pointing where the fault would be that would allow for the hazard light to come on with the flasher control switch in both the on and off position. if any one can make sense of this the help would be much appreciated thanks.
Ok i just tested the hazard switch. it appears to be in working order. i tested for ohms from terminal to terminal. i found that there was resistance from terminal 1 to 3 with the switch in the off position. there was no other resistance across any terminal with the switch in the off position. with the switch in the on position i found there to be resistance from terminal 1 to terminal 2.
