MP3 Aftermarket Guide--UPDATED 03-14-03
Status
Not open for further replies.
NC_MP3
This is an aftermarket guide I have put together. It is now in html format. Simply click on the appropriate category and you will be taken to it.
Please post additions, corrections, or suggestions here: <A HREF=http://www.mazdamp3.com/vbb225/showthread.php?s=&threadid=6415 TARGET=NEW>AFTERMARKET GUIDE ADDITIONS</A><BR>
<BR>
<A NAME=#0>MAZDA MP3 AFTERMARKET GUIDE</A><BR>
<BR>
<A HREF=#00>ENGINE</A><BR>
<A HREF=#01>INTAKES</A><BR>
<A HREF=#02>EXHAUST</A><BR>
<A HREF=#03>FORCED INDUCTION</A><BR>
<A HREF=#04>COOLING</A><BR>
<A HREF=#05>DRIVETRAIN</A><BR>
<A HREF=#06>SUSPENSION</A><BR>
<A HREF=#07>BRAKES</A><BR>
<A HREF=#08>EXTERIOR</A><BR>
<A HREF=#09>INTERIOR</A><BR>
<A HREF=#10>FUEL SYSTEM</A><BR>
<BR>
<BR>
<A NAME=#00><FONT COLOR=DC143C>ENGINE</FONT></A><BR>
<A HREF=#001>JDM ENGINES</A><BR>
<A HREF=#002>BOTTOM END</A><BR>
<A HREF=#003>VALVE TRAIN</A><BR>
<A HREF=#004>OTHER</A><BR>
<BR>
<A NAME=#001><FONT COLOR=006699>JDM ENGINES</FONT></A><BR>
FS-ZE Engine<BR>
This is the engine that comes in the Japanese Sport 20. It is rated at 170 HP and bolts right in to the MP3. Engines are from wrecked Japanese cars with low miles. Comes with fuel injectors, intake, and exhaust manifold. ECU is not included but can be purchased.<BR>
Price: $1,950.00<BR>
<A HREF=HTTP://WWW.CORKSPORT.COM TARGET=NEW>CORKSPORT</A><BR>
<BR>
<A HREF=#00>BACK TO ENGINE</A><BR>
<A HREF=#0>BACK TO TOP</A><BR>
<BR>
<A NAME=#002><FONT COLOR=006699>BOTTOM END</FONT></A><BR>
Thomas Knight Stroker Kit<BR>
2150cc stroker kit that features forged rods and pistons. Includes crank, rods, bearings, pistons, rings and pins.<BR>
Price: $1,995.00<BR>
<A HREF=http://www.knightturbos.com TARGET=NEW>KNIGHT TURBO</A><BR>
<BR>
Mazdaspeed High Compression Pistons<BR>
These are 10.7:1 pistons for the 2.0. HP gain is unknown.<BR>
Price: $42.00 for each piston<BR>
<A HREF=http://www.mazdamotorsports.com TARGET=NEW>MAZDAMOTORSPORTS</A><BR>
<BR>
Tripoint Engineering Aluminum Flywheel<BR>
Aluminum Flywheel for the 2.0. Weighs approx. 7.42 lbs. Stock flywheel weighs about 18.5 lbs.<BR>
Price: $389.00<BR>
<A HREF=http://www.tripointengineering.com TARGET=NEW>TRIPOINT</A><BR>
<BR>
Indigo Flywheel<BR>
Aluminum Flywheel for the 2.0. Weight is unknown.<BR>
Price: $439.00<BR>
<A HREF=http://www.srmotorsports.com TARGET=NEW>SRMOTORSPORTS</A><BR>
<BR>
Mazdamotorsports 15lb Flywheel<BR>
This flywheel is lightened 3 lbs from stock.<BR>
Price: $138.65<BR>
<BR>
Fidanza Billet Flywheel<BR>
This is a flywheel for the 2.0L engine. It weighs in at only 9 lbs.<BR>
Price: $260<BR>
<A HREF=http://www.rr-racing.com TARGET=NEW>RR RACING</A><BR>
<BR>
<BR>
<A NAME=#003><FONT COLOR=006699>VALVE TRAIN</FONT></A><BR>
Mazdaspeed Exhaust Camshaft<BR>
This is a more aggressive exhaust cam for the 2.0 L FS engine. It has not been tested, but this cam w/ the intake cam only added about 5 WHP.<BR>
Price: $142.00<BR>
<A HREF=http://www.corksport.com TARGET=NEW>CORKSPORT</A><BR>
<BR>
FS-ZE Intake Camshaft<BR>
This is an intake cam from the Japanese FS-ZE engine. This will fit right in the MP3. This and the Mazdaspeed exhaust cam added about 5 WHP.<BR>
Price: $168.00<BR>
<BR>
Billet Exhaust Cam<BR>
This is a blank cam. Journels are ground but lobes are not, meaning you can have it ground to any spec you want.<BR>
Price: $71.55<BR>
<BR>
Billet Intake Cam<BR>
Price: $73.05<BR>
<BR>
Tripoint Engineering Adjustable Cam Gears<BR>
Adjustable Cam Gears for the 2.0. Black gear w/ blue anodized center. Timing marks on the gear. Bolts right on.<BR>
Price: $299.00<BR>
<BR>
FS-ZE Valve Springs<BR>
These are valve springs from the Japanese FS-ZE. It is unknown if they are stiffer than stock MP3 or not.<BR>
Price: $48.30 each<BR>
<BR>
<BR>
<A NAME=#004><FONT COLOR=006699>OTHER</FONT></A><BR>
Indigo Underdrive Main Pulley<BR>
This pulley is 15% smaller in diameter than stock. It replaces the crank pulley and includes new belts. HP gains are unknown.<BR>
Price: $249.00<BR>
<A HREF=http://www.srmotorsports.com TARGET=NEW>SR MOTORSPORTS</A><BR>
<BR>
Indigo Alternator/Water Pump Pulley Set<BR>
Made of aluminum and with a 15% reduced diameter these pulleys will reduce the amount of HP needed to turn the alternator and water pump. Fits the 2.0L engine.<BR>
Price: $199.00<BR>
<BR>
AWR Engine Mounts<BR>
These are urethane engine mounts for the 2.0. These should reduce wheel hop.<BR>
Price: $145.00<BR>
<A HREF=http://www.awrracing.com TARGET=NEW>AWR RACING</A><BR>
<BR>
<BR>
<BR>
<A NAME=#01><FONT COLOR=DC143C>INTAKES</FONT></A><BR>
<BR>
AEM Short Ram Intake<BR>
Short Ram intake system for the 2.0L engine. Comes in blue, red, and silver. Price: $203.13<BR>
<A HREF=http://www.nopionline.com TARGET=NEW>NOPI</A><BR>
<BR>
Injen Intake System<BR>
Cold Air Intake for the 2.0. Polished aluminum.<BR>
Price: $258.00<BR>
<A HREF=http://www.mazdaformance.com TARGET=NEW>MAZDAFORMANCE</A><BR>
<BR>
Indigo Intake System<BR>
This intake is made of polished aluminum and comes with all hardware and hoses. Filter is included.<BR>
Price: $249.00<BR>
<BR>
<A HREF=#01>BACK TO INTAKES</A><BR>
<BR>
<BR>
<A NAME=#02><FONT COLOR=DC143C>EXHAUST</FONT></A><BR>
<A HREF=#021>CAT BACK</A><BR>
<A HREF=#022>FULL EXHAUST</A><BR>
<A HREF=#023>HEADERS</A><BR>
<A HREF=#024>MUFFLERS</A><BR>
<BR>
<A NAME=#021><FONT COLOR=006699>CAT BACK</FONT></A><BR>
Borla Cat Back<BR>
Stainless Steel cat back exhaust for the Protg, should work fine with the MP3.<BR>
Price: $478.80<BR>
<BR>
SRMotorsports Cat Back Exhaust<BR>
Made of 2.25 inch mandrel bent pipe this cat back system has a claimed HP increase of 9 HP. It has a 3 inch stainless steel tip. It comes with a gasket and all hardware needed.<BR>
Price: $449.00<BR>
<BR>
<A HREF=#02>BACK TO EXHAUST</A><BR>
<BR>
<A NAME=#022><FONT COLOR=006699>FULL EXHAUST</FONT></A><BR>
<BR>
<BR>
<A NAME=#023><FONT COLOR=006699>HEADERS</FONT></A><BR>
HP Racing Exhaust Header<BR>
Two piece 4-2-1 header for the 01+ Protg/MP3. Comes in ceramic or chrome finish.<BR>
Price: $206.91, $173.79 respectively.<BR>
<BR>
<BR>
<A NAME=#024><FONT COLOR=006699>MUFFLERS</FONT></A><BR>
<BR>
<BR>
<A NAME=#03><FONT COLOR=DC143C>FORCED INDUCTION</FONT></A><BR>
<A HREF=#031>TURBO KITS</A><BR>
<A HREF=#032>TURBO MANIFOLDS</A><BR>
<A HREF=#033>OTHER</A><BR>
<BR>
<A NAME=#031><FONT COLOR=006699>TURBO KITS</FONT></A><BR>
Tripoint Engineering Turbo Kit<BR>
This kit consist of an Aerodyne Turbo Charger, Tri-Point Engineering Front Mount Intercooler, Tri-Point Engineering AIC (additional Injector controller), 2 additional injectors, Intake Piping, Down Pipe, Autometer Boost gauge, Mazda Blow Off Valve, Clamps and coupling hoses. This kit provided a gain of 67 HP.<BR>
Price: $3,800.00<BR>
<BR>
SPOOL Starter Kit<BR>
This kit includes the SPOOL manifold along with a Ballistic Garrette turbo and steel braided oil lines.<BR>
Price: $1,600.00<BR>
<A HREF=http://www.spool-turbo.com TARGET=NEW>SPOOL ITS</A><BR>
<BR>
SPOOL Stage 1 Turbo Kit<BR>
This kit uses the SPOOL shorty style manifold with a Garrett T3 turbo. Kit includes everything you need to run 4-5 psi. This is a non intercooled setup. Can be upgraded to Stage 2-4.<BR>
Price: $2,595<BR>
<BR>
SPOOL Stage 2 Turbo Kit<BR>
This is the same as the stage 1 but uses a more equal length race style manifold.<BR>
Price: $2,795<BR>
<BR>
SPOOL Stage 3 Intercooler Upgrade<BR>
This is an add on intercooler for the Stage 1 and 2 kits. The intercooler is a huge front mount PWR unit. With proper tuning this kit can be run up to 8 psi.<BR>
Price: $900<BR>
<BR>
SPOOL Stage 4 Upgrade<BR>
Coming Soon. This will be a solution to the stock Mazda ECU. It will be some sort of piggy back computer to control timing and fuel, but will not be a full stand alone ECU. With proper tuning of the fuel and timing, and use of bigger injectors, the MP3 should be able to handle 10-12 psi.<BR>
Price: TBA<BR>
<BR>
Flyin Protg (Flyin Miata) Turbo Kit<BR>
This is a complete turbo kit from Flyin Protege. It features a log style, cast iron manifold, a Garrette T03 turbo, and a small front mount (sort of) intercooler. Comes complete with everything you need, boost gauge, blow off valve, everything.<BR>
Price: $3,595<BR>
<A HREF=http://www.flyinmiata.com/protege TARGET=NEW>FLYIN PROTEGE</A><BR>
<BR>
Mazdaformance Turbo Kit<BR>
In development.<BR>
<BR>
<A HREF=#03>BACK TO FORCED INDUCTION</A><BR>
<BR>
<A NAME=#032><FONT COLOR=006699>TURBO MANIFOLDS</FONT></A><BR>
SPOOL Cast Iron Tubular Manifold<BR>
This is a cast iron tubular manifold made specifically for the 2.0. This manifold is made to fit a T3 turbo and utilizes an external wastegate (sold serperately). Ceramic coating is also available for an added fee.<BR>
Price: $700.00<BR>
<BR>
SPOOL Shorty Style Manifold<BR>
This is also a cast iron, tubular manifold, but uses shorter runners that are not equal length. Use an external wastegate<BR>
Price: $550<BR>
<BR>
<BR>
<A NAME=#033><FONT COLOR=006699>OTHER</FONT></A><BR>
<BR>
<BR>
<BR>
<A NAME=#04><FONT COLOR=DC143C>COOLING</FONT></A><BR>
<A HREF=#041>RADIATORS</A><BR>
<BR>
<A NAME=#041><FONT COLOR=006699>RADIATORS</FONT></A><BR>
SRMotorsports SC Radiator<BR>
Made from fully TIG welded aluminum these radiators offer 40-60% more cooling. Made to be a perfect factory fit.<BR>
Price: $529.00<BR>
<BR>
<A HREF=#04>BACK TO COOLING</A><BR>
<BR>
<BR>
<A NAME=#05><FONT COLOR=DC143C>DRIVETRAIN</FONT></A><BR>
<A HREF=#051>CLUTCH</A><BR>
<A HREF=#052>TRANSMISSION</A><BR>
<A HREF=#053>SHIFTERS</A><BR>
<BR>
<A NAME=#051><FONT COLOR=006699>CLUTCH</FONT></A><BR>
ACT Clutch Kit<BR>
ACT makes a clutch for the 2.0. You only have one choice for the pressure plate, which is the heavy duty pressure plate. There are 3 disks available: street, 4 puck, and 6 puck. The street disk is recommended for daily driving. The 4 and 6 puck grab harder and hold more power but are harsh. Kit includes pressure plate, disk, pilot, and throw out bearings.<BR>
Price: $391.00<BR>
<BR>
<A HREF=#05>BACK TO DRIVETRAIN</A><BR>
<BR>
<A NAME=#052><FONT COLOR=006699>TRANSMISSION</FONT></A><BR>
Quaife LSD<BR>
Limited Slip Differential for the 2.0. LSDs provide better traction and handling by transferring equal amounts of power to both front wheels.<BR>
Price: $1,227.00<BR>
<BR>
4.833 Final Drive Gear<BR>
Lower final drive gear should provide better acceleration. Fits all G type trannys (MP3 uses G25M-R Tranny).<BR>
Price: $2,368.55<BR>
<BR>
<BR>
<A NAME=#053><FONT COLOR=006699>SHIFTERS</FONT></A><BR>
B&M Short Shifter<BR>
This shifter provides about 40% reduction in throw. Includes stiffer bushings as well.<BR>
Price: $144.00<BR>
<BR>
Kartboy Short Shifter w/ Bushings<BR>
This is a short throw shifter for the MP3 complete with stiffer bushings.<BR>
Price: $100.00<BR>
<A HREF=http://kartboy.com TARGET=NEW>KARTBOY</A><BR>
<BR>
SRMotorsports Short Shifter<BR>
This is a short throw shifter for the MP3.<BR>
Price: $179.00<BR>
<BR>
<BR>
<BR>
<A NAME=#06><FONT COLOR=DC143C>SUSPENSION</FONT></A><BR>
<A HREF=#061>SPRINGS</A><BR>
<A HREF=#062>SWAY BARS</A><BR>
<A HREF=#063>COILOVERS</A><BR>
<A HREF=#064>SHOCKS</A><BR>
<A HREF=#065>STRUT BARS</A><BR>
<BR>
<A NAME=#061><FONT COLOR=006699>SPRINGS</FONT></A><BR>
Ground Control Adjustable Springs<BR>
These springs can be adjusted so you can fine tune your ride height. Fits right on the MP3.<BR>
Price: $375.00<BR>
<BR>
Eibach Pro Lowering Springs<BR>
Unknown how much of a drop these are.<BR>
Price: $249.95<BR>
<BR>
SRMotorsports HP Spring Kit<BR>
Lowers the Protg 1.35 inches. Since we have Racing Beat springs it is unknown how much of a drop these will give the MP3.<BR>
Price: $265.00<BR>
<BR>
<A HREF=#06>BACK TO SUSPENSION</A><BR>
<BR>
<A NAME=#062><FONT COLOR=006699>SWAY BARS</FONT></A><BR>
SRMotorsports Rear Sway Bar Set<BR>
This is a 19mm tubular chrome moly sway bar. This may not provide any more of a performance gain over out stock Racing Beat sway bar, but I put this one in here anyway.<BR>
Price: $189.00<BR>
<BR>
<BR>
<A NAME=#063><FONT COLOR=006699>COILOVERS</FONT></A><BR>
SR Motorsports Coilover Set<BR>
Fully adjustable coil over kit for the MP3. 2.5 inch springs, various springs rates.<BR>
Price: $1,499.00<BR>
<BR>
<BR>
<A NAME=#064><FONT COLOR=006699>SHOCKS</FONT></A><BR>
Mazdaspeed Adjustable Shocks<BR>
4 and 5 way adjustable. Fits MP3.<BR>
Price: $179.00 each<BR>
<BR>
<BR>
<A NAME=#065><FONT COLOR=006699>STRUT BARS</FONT></A><BR>
DGMotorsports Carbon Fiber Strut Bar<BR>
Real carbon fiber strur bar for the 2.0<BR>
Price: $295.00<BR>
<A HREF=http://www.dgmotorsports.com TARGET=NEW>DGM</A><BR>
<BR>
SRMotorsports Strut Brace<BR>
This brace is made of aluminum and has your choice of red, blue, black, and yellow ends.<BR>
Price: $169.00<BR>
<BR>
<BR>
<A NAME=#07><FONT COLOR=DC143C>BRAKES</FONT></A><BR>
<A HREF=#071>BRAKE KITS</A><BR>
<A HREF=#072>ROTORS</A><BR>
<A HREF=#073>PADS</A><BR>
<A HREF=#074>LINES</A><BR>
<BR>
<A NAME=#071><FONT COLOR=006699>BRAKE KITS</FONT></A><BR>
StopTech Front Big Brake Kit<BR>
This is a Big Brake Kit for the front only.<BR>
The kit includes:<BR>
- 2 Piece Floating Directional 328mm x 28mm AeroRotors, Cross-Drilled.<BR>
- 4 Piston ST40 Calipers, Painted Red.<BR>
- 7075 T6 Billet Aluminum Caliper Brackets.<BR>
- 7075 T6 Billet Aluminum Hats.<BR>
- Stainless Steel Brake Lines.<BR>
- AXXIS Ultimate Brake Pads.<BR>
- All Necessary Hardware.<BR>
Price: $1,795.00<BR>
<BR>
RR-Racing Big Brake Kit Full Race<BR>
This is a full big brake kit for the front brakes only. This kit comes with rotors from 12.2 inch all the way up to 13 inches in diameter and are 1.25 inches thick. Also comes with 4-piston calipers, and all hardware needed for the conversion. May not work with stock sized rims.<BR>
Price: $1100 - $1600<BR>
<BR>
RR-Racing Big Brake Kit<BR>
This is a big brake kit for the front only. Converts to 2-piece 12.0" diameter, 1" thick, directional curved vane rotors w/ stock calipers. Utilizes billet aluminum rotor hat, billet caliper relocation brackets, and available cross drilled or slotted (no additional cost) rotors. Works with stock sized rims.<BR>
Price: $580<BR>
<BR>
<A HREF=#07>BACK TO BRAKES</A><BR>
<BR>
<A NAME=#072><FONT COLOR=006699>ROTORS</FONT></A><BR>
SRMotorsports Rotors<BR>
These rotors come either slotted or drilled. Front and back available.<BR>
Price: $119.00 each<BR>
<BR>
<BR>
<A NAME=#073><FONT COLOR=006699>PADS</FONT></A><BR>
SRMotorsports High Performance Brake Pads<BR>
High performance brake pads for the MP3<BR>
Price: $89.00 /set<BR>
<BR>
<BR>
<A NAME=#074><FONT COLOR=006699>LINES</FONT></A><BR>
Steel Braided Brake Line Kit<BR>
These steel braided lines will give you a much firmer brake pedal. Comes with all needed hardware.<BR>
Price: $129.00<BR>
<BR>
<BR>
<BR>
<A NAME=#08><FONT COLOR=DC143C>EXTERIOR</FONT></A><BR>
<A HREF=#081>BODY KITS</A><BR>
<A HREF=#082>HOODS</A><BR>
<A HREF=#083>TAIL LIGHTS</A><BR>
<A HREF=#084>OTHER</A><BR>
<BR>
<A NAME=#081><FONT COLOR=006699>BODY KITS</FONT></A><BR>
Wings West Body Kit<BR>
Wings West makes a body kit for the MP3. Basic kit includes front bumper replacement, 2 side skirts, and a rear lip type spoiler. There is also an additional fender flare kit, a hood bonnet, and a rear window, umm, thing.<BR>
Price: $660.00 for the 4 piece kit<BR>
<A HREF=http://www.nextcollection.com TARGET=NEW>NEXT COLLECTION</A><BR>
<BR>
<A HREF=#08>BACK TO EXTERIOR</A><BR>
<BR>
<A NAME=#082><FONT COLOR=006699>HOODS</FONT></A><BR>
APC W Vented Carbon Fiber Hood<BR>
This is a W vented carbon fiber hood for the MP3.<BR>
Price: $649.00<BR>
<A HREF=http://www.4apc.net TARGET=NEW>APC</A><BR>
You can order the hood from Pep Boys for $649.00 You can also get it from Autozone and Advance Auto for $699.00<BR>
<BR>
Tripoint Engineering Carbon Fiber Hood<BR>
Carbon Fiber hood for the MP3. Hood is OEM meaning it is the same as stock but carbon fiber.<BR>
Price: $475.00<BR>
<BR>
DGMotorsports Ram Air Carbon Fiber Hood<BR>
This is a carbon fiber hood with a functional scoop on the drivers side.<BR>
Price: $1,195.00<BR>
<BR>
DGMotorsports Carbon Fiber Hood<BR>
This is the same as above but without the ram air scoop.<BR>
Price: $695.00<BR>
<BR>
<BR>
<A NAME=#083><FONT COLOR=006699>TAIL LIGHTS</FONT></A><BR>
APC Euro Tail Lights<BR>
Euro or Altezza type tail lights for the 01 + Protg/MP3. Comes in carbon look, original, and generation 2 styles.<BR>
Price: $162.70, $142.86, $171.95 respectively.<BR>
<A HREF=http://www.Nopionline.com TARGET=NEW>NOPI</A><BR>
<BR>
<BR>
<A NAME=#084><FONT COLOR=006699>OTHER</FONT></A><BR>
DGMotorsports Carbon Fiber Downforcers<BR>
These attach to the bottom of the front bumber on the right and left corner.<BR>
Price: $179.95<BR>
<BR>
DGMotorsports Carbon Fiber Side Skirts<BR>
These are real carbon fiber side skirts. They are listed for the P5, but should work for the MP3 as well.<BR>
Price: $395.00<BR>
<BR>
DGMotorsports Carbon Fiber Eyelids<BR>
These are real carbon fiber eyelids for the MP3 headlights.<BR>
Price: $59.95<BR>
<BR>
DGMotorsports Carbon Fiber Front Lip<BR>
This is a real carbon fiber lip type spoiler for the MP3 front bumper.<BR>
Price: $375.00<BR>
<BR>
DGMotorsports Carbon Fiber Rear Valance<BR>
This is a real carbon fiber lip type valance for the MP3 rear bumper.<BR>
Price: $199.00<BR>
<BR>
DGMotorsports Carbon Fiber Front End<BR>
This is a whole front clip made from carbon fiber. It is all one piece as well. It is listed for the P5, but should work for the MP3.<BR>
Price: $1,495.00<BR>
<BR>
DGMotorsports Fiberglass Front End<BR>
Same as above but made out of fiberglass.<BR>
Price: $895<BR>
<BR>
<BR>
<BR>
<A NAME=#09><FONT COLOR=DC143C>INTERIOR</FONT></A><BR>
<A HREF=#091>GAUGE FACES</A><BR>
<A HREF=#092>ROLL CAGES</A><BR>
<A HREF=#093>DASH KITS</A><BR>
<BR>
<A NAME=#091><FONT COLOR=006699>GAUGE FACES</FONT></A><BR>
Indiglo Gauge Faces<BR>
Includes Generation 2, 6 stage digital inverter. Blue/light blue/bluegreen/green/violet/lightgreen, pure white in the day with scratch resistant surface.<BR>
Price: $49.00<BR>
<A HREF=http://www.procarparts.com TARGET=NEW>PROCARPARTS</A><BR>
<BR>
<A HREF=#09>BACK TO INTERIOR</A><BR>
<BR>
<A NAME=#092><FONT COLOR=006699>ROLL CAGES</FONT></A><BR>
<BR>
<BR>
<A NAME=#093><FONT COLOR=006699>DASH KITS</FONT></A><BR>
<BR>
<BR>
<BR>
<A NAME=#10><FONT COLOR=DC143C>FUEL SYSTEM</FONT></A><BR>
<A HREF=#101>INJECTORS</A><BR>
<BR>
<A NAME=#101><FONT COLOR=006699>INJECTORS</FONT></A><BR>
RR-Racing Injectors<BR>
RR-Racing is selling modified injectors for the MP3. Injectors can be modified to up to 700cc.<BR>
Price: $380<BR>
END
Status
