Motor mounts
2001 Mazda Protege MP3
Ok so mine are going pretty fast and I just wanna know the best kind to get. My buddy has a speed and he put the racing ones in and now his whole car vibrates really bad. I dont want that but I still want to be able to launch good and want it to sit sturdy. What brand would be the best to go with??
Awr is by far the best aftermarket. But if your worried about vibes get either sls(not recommended) or sheepunit
Majority of the times when you switch from OEM mounts to performance mounts there will be an increase in vibrations. Thats the sacrifice we make when we choose performance over comfort. If you decide to go with AWR get 70 durometer which is softer. :)
I've got mideival front and rear mounts with awr side inserts, had the insert in at first and there was hardly no additional vibration, but after I got the front and rear solid mounts in... I said goodbye to wheel hop forever
You can safely install a front solid mount with minimal vibration feedback. You get the most vibrations from doing the rear mount. I suggest an AWR front mount of 88 duro and see what that gets you. Very easy to change (30 mins) and you'll def notice an improvement in the launch with hardly any vibrations. I speak from experience, cause this is how I did it. I installed the rear mount a couple months later after deciding I wanted to get rid of all wheel hop, not just reduce it. Vibrations increased greatly, but not enough for me to remove it...yet.
